[GRASS5] v.digit color name mismatch
Bernhard Reiter
bernhard at intevation.de
Mon Feb 24 10:41:54 EST 2003
Cheg,
thanks for your help!
Can you add your solution to bug report #1670?
https://intevation.de/rt/webrt?serial_num=1670&display=History
This is possible using email.
mail to grass-bugs a t intevation.de
having the following string within the subject line:
[bug #1670]
If you can produce a patch against CVS head
somebody with CVS access will commit it.
Thanks again,
Bernhard
On Sun, Feb 23, 2003 at 09:59:49PM -0800, cheg01 at attbi.com wrote:
> I found the source of the incorrect behavior of the
> v.digit->Customize->Color menu. The color names do not match the colors
> used in the display fo the following reason:
> The colors used in the display are defined in the file
> <grass_dir>/src/include/colors.h:
> #define D_COLOR_LIST:
> "red,orange,yellow,green,blue,indigo,violet,white,black,gray,brown,magenta,
> aqua,grey"
> The color names used in v.digit are defined in the file
> <grass_dir>/src/mapdev/v.digit/color.c:
> static char *color_names[] = {
> " white",
> " black",
> " yellow",
> " blue",
> " red",
> " green",
> " orange",
> " grey",
> " magenta",
> " aqua",
> " indigo",
> " violet",
> " brown",
> To fix it, edit the color_names list to match the D_COLOR_LIST and
> recompile v.digit.
