[GRASS5] Grass 5.1 compile error
Glynn Clements
glynn.clements at virgin.net
Wed Feb 26 16:37:39 EST 2003
Radim Blazek wrote:
> > 1. Why are these paths hardcoded, instead of using the values from the
> > configure script?
> I used head.in from 5.0 as template for Platform.make.in and there
> it was hardcoded. I think, that if something is obviously wrong,
> anybody can fix it.
Sorry; I didn't realise that it was that old. I had assumed that
PNGINC had been specifically changed. I'll look into synchronising
Platform.make.in with the latest head.in from 5.0.
> > 2. Why is $(PNGINC) being used for compiling libgis?
> ALLINC = $(INC) $(PNGINC) $(ODBCINC) $(PQINCPATH)
> and ALLINC is used in default rules. This is probably wrong,
I hope so (i.e. I hope that these packages aren't required by
everything).
> we can remove $(PNGINC) and use EXTRA_INCL in modules,
> but what to do with ODBCINC and PQINCPATH? Those must be used
> in all vector libraries and modules. Is it necessary to define something
> like EXTRA_INCL = $(VECT_INCL) in all vector modules
Yes.
> or it is not harmful in default rules (ALLINC).
The default rules should be limited to switches which are required by
all modules; e.g. anything which the user specifies via the
--with-includes switch, plus the GRASS51 include directory.
Switches which are specific to vector modules[1] should only be used
by vector modules.
[1] I know that "vector modules" and "GRASS 5.1" are basically the
same thing at present but it won't always be that way.
Glynn Clements <glynn.clements at virgin.net>
