[GRASS5] Grass 5.1 make htmldocs problem
Markus Neteler neteler at itc.it
Thu Feb 27 03:12:35 EST 2003
On Wed, Feb 26, 2003 at 05:48:38PM -0800, cheg01 at attbi.com wrote:
> "make htmldocs" fails on 5.1 under Solaris 8 Sparc because the "type"
> command does not accept the "-p" switch. It can be fixed by changing
> "type -p" to "type" in /lib/db/Makefile and /lib/vector/Makefile.
Ok, I have tested on Linux and submitted the proposed change.
Markus
