[GRASS5] test module linking problem
manderso at cs.wisc.edu manderso at cs.wisc.edu
Thu Feb 27 14:37:14 EST 2003
Hi --
I've been trying to get just a tiny little baby test grass module to
compile, and I'm running into a linking problem.  I attempted to compile the
program:
  g++ -c -o pointdump.o pointdump.cpp -I/scratch/grass/src/grass5.0.1/src/include
and then to link it:
  g++ -L/scratch/grass/src/grass5.0.1/src/libes/LIB.i686-pc-linux-gnu\
      -L/u/m/a/manderso/grass/lib\
      -L/s/lapack/lib\
      -o pointdump\
      pointdump.o\
      -lvect -ldig2 -lgis -ldig_atts\
      /scratch/grass/src/grass5.0.1/src/libes/vect32/libes/LIB.i686-pc-linux-gnu/libtrans.a\
      -lvask -lncurses -ltermcap -lbsd-compat -lm  -lz
  pointdump.o: In function `main':
  pointdump.o(.text+0x1c): undefined reference to `G_gisinit(char*)'
  pointdump.o(.text+0x21): undefined reference to `G_define_option()'
  pointdump.o(.text+0x86): undefined reference to `G_parser(int, char**)'
  pointdump.o(.text+0xbb): undefined reference to `G_find_vector2(char*, char*)'
  pointdump.o(.text+0xe3): undefined reference to `Vect_open_old(Map_info*, char*, char*)'
  pointdump.o(.text+0xf3): undefined reference to `G_fatal_error(char*, ...)'
  pointdump.o(.text+0xf8): undefined reference to `Vect_new_line_struct()'
  pointdump.o(.text+0x116): undefined reference to `Vect_read_next_line(Map_info*, line_pnts*)'
  pointdump.o(.text+0x1a2): undefined reference to `Vect_destroy_line_struct(line_pnts*)'
  pointdump.o(.text+0x1b0): undefined reference to `Vect_close(Map_info*)'
Initially I had tried to do this in one step, and to only try to link
against -lgis and -lvect, but the linking errors were the same either way.
I got the more elaborate gcc incantation used here by looking at how the
grass build process compiled a vector module (v.transform, specifically).
I used nm to look at the symbols inside of libgis.a and libvect.a, which
live in
and the symbols it is complaining about do seem to be there.
The code to pointdump.cpp is very simple (though undebugged, as I haven't
gotten it to link yet)...it is attached below.  Any ideas on why the linking
is failing?
Any help is much appreciated.  Thanks.
#include "gis.h"
#include "Vect.h"
#include <iostream>
using std::cout;
using std::cerr;
using std::endl;
int main(int argc, char *argv[]) {
   struct Map_info Map; /* Map info */
   struct line_pnts *Points; /* Poly-Line data */
   G_gisinit (argv[0]); /* init GIS lib */
   struct Option *input;
   input = G_define_option();
   input->key             = "input";
   input->type            = TYPE_STRING;
   input->required        = YES;
   input->multiple        = NO;
   input->gisprompt       = "old,dig,vector";
   input->description     = "vector input file";
   if (G_parser (argc, argv)) {exit (-1);}
   char *name = input->answer;
   char *mapset;
   mapset = G_find_vector2(name,"");
   if (0 > Vect_open_old (&Map, name, mapset)) { /* open file */
      G_fatal_error ("Cannot open vector file");
   Points = Vect_new_line_struct();
   while (0 < Vect_read_next_line (&Map, Points)) {
      cout << "x:" << *(Points->x) << " y:" << *(Points->y) << endl;
   Vect_destroy_line_struct(Points); /* remove allocation */
   Vect_close(&Map); /* close up */
Matt C. Anderson          email: manderso at cs.wisc.edu
	                    web: http://www.cs.wisc.edu/~manderso
      No thank you Delmar.  A third of a gopher would only
      arouse my appetite without bedding her back down...
