[GRASS5] White spaces support
Markus Neteler neteler at itc.it
Thu Feb 27 18:04:33 EST 2003
On Thu, Feb 27, 2003 at 08:39:15PM +0000, Glynn Clements wrote:
> Also, in most of the cases where users have had problems due to
> whitespace, the problem has been due to their home directory rather
> than GISDBASE. This is arguably a more serious problem, as the user
> can choose where to put GISDBASE, but they don't necessarily get to
> choose their home directory.
Now I have tried with spaces in the /home/user dir/ and fixed
the lister and r.info. The main problem, as you stated earlier,
are all the [G_]system() calls.
g.list works now,  d.mon as well (also d.rast etc).
Any Windows tester may update again and try.
Markus
