[GRASS5] Grass51 compile error
Harald Wehr
hwehr at hs-harz.de
Fri Feb 28 04:56:34 EST 2003
I wanted to try the new vector features in grass51 but I get following
error during the make-process:
postgres
make[3]: Wechsel in das Verzeichnis
»/home/harald/sourcen/grass51/db/drivers/postgres«
make[3]: *** Keine Regel vorhanden, um das Target »-lpq«,
benötigt von
»/home/harald/sourcen/grass51/dist.i686-pc-linux-gnu/driver/db/pg«, zu
erstellen. Schluss.
make[3]: Verlassen des Verzeichnisses
make[2]: *** [subdirs] Fehler 1
make[2]: Verlassen des Verzeichnisses
»/home/harald/sourcen/grass51/db/drivers«
make[1]: *** [subdirs] Fehler 1
make[1]: Verlassen des Verzeichnisses »/home/harald/sourcen/grass51/db«
make: *** [default] Fehler 1
harald at laptop:~/sourcen/grass51>
I think it is due to the message "no rule to make target -lpq". What can
I do here?
Here are some information about my system:
-SuSE Linux 8.1
-Grass50 snapshot experimental from 2003_02_22 (compiled and installed
without any problems)
-Postgres 7.3
Here is how i call the configure-script of grass51:
CFLAGS="-g -Wall" ./configure
--prefix=/home/harald/programs/grass_exp \
--with-postgres-includes=/home/mobiharz/programme/postgres/include\
--with-postgres-libs=/home/mobiharz/programme/postgres/lib \
--with-tcltk-includes=/home/harald/programs/tcltk/include \
--with-tcltk-libs=/home/harald/programs/tcltk/lib \
--with-grass50=/home/harald/sourcen/grass50_exp_2003_02_22
The output of configure looks like this:
GRASS is now configured for i686-pc-linux-gnu
Source directory: /home/harald/sourcen/grass51
Build directory: /home/harald/sourcen/grass51
Installation directory: /home/harald/programs/grass_exp/grass5
C compiler: gcc -g -O2
FORTRAN compiler:
NVIZ: yes
X11 support: yes
DBM support: no
JPEG support: yes
TIFF support: yes
PNG support: yes
GD support: yes
Tcl/Tk support: yes
PostgreSQL support: yes
MySQL support: no
OpenGL(R) support: yes
ODBC support: yes
FFTW support: yes
BLAS support: no
LAPACK support: no
Motif support: no
FreeType support: no
GLw support: no
NLS support: no
Readline support: no
Can you help me?
Thanks.
Harald
