[GRASS5] Grass51 compile error
Radim Blazek
blazek at itc.it
Fri Feb 28 07:55:01 EST 2003
On Friday 28 February 2003 10:56 am, Harald Wehr wrote:
> I wanted to try the new vector features in grass51 but I get following
> error during the make-process:
> postgres
> make[3]: Wechsel in das Verzeichnis
> »/home/harald/sourcen/grass51/db/drivers/postgres«
> make[3]: *** Keine Regel vorhanden, um das Target »-lpq«,
> benötigt von
> »/home/harald/sourcen/grass51/dist.i686-pc-linux-gnu/driver/db/pg«, zu
> erstellen. Schluss.
> make[3]: Verlassen des Verzeichnisses
> make[2]: *** [subdirs] Fehler 1
> make[2]: Verlassen des Verzeichnisses
> »/home/harald/sourcen/grass51/db/drivers«
> make[1]: *** [subdirs] Fehler 1
> make[1]: Verlassen des Verzeichnisses »/home/harald/sourcen/grass51/db«
> make: *** [default] Fehler 1
> harald at laptop:~/sourcen/grass51>
> I think it is due to the message "no rule to make target -lpq". What can
> I do here?
Update grass51/db/drivers/postgres/Makefile from CVS
or remove "$(LIBES)" from "$(DRIVER): $(ARCH_OBJS) $(LIBES)"
Radim
