[GRASS5] [bug #1501] (grass) installation under SUSE 8.1 is
Request Tracker
grass-bugs at intevation.de
Wed Jan 8 18:50:26 EST 2003
this bug's URL: http://intevation.de/rt/webrt?serial_num=1501
Subject: installation under SUSE 8.1 is
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: 5.0.0
Hi, after installing GRASS 5.0.0 under SUSE 8.1 and running grass5 command,
the following message is generated:
Starting GRASS ...
/usr/local/grass5/etc/set_data: error while loading shared libraries:
libtermcap.so.2: cannot open shared object file: No such file or directory
jirid at linux:~>
Installation under RedHat 7.0 worked fine. I assume that SUSE 8.1 will
install pretty much the same set of libraries.
Any suggestions?
Thanks, Jiri
Jiri Doskocil
GIS System Manager
IRMP Office
Hawks Dr.
Jicarilla Apache Nation
Dulce, NM 87528
Any suggestions
-------------------------------------------- Managed by Request Tracker
