[GRASS5] [bug #1501] (grass) installation under SUSE 8.1 is
Markus Neteler neteler at itc.it
Thu Jan 9 02:30:23 EST 2003
On Thu, Jan 09, 2003 at 03:46:12AM +0000, Glynn Clements wrote:
> Request Tracker wrote:
> > Hi, after installing GRASS 5.0.0 under SUSE 8.1 and running grass5 command,
> > the following message is generated:
> > Starting GRASS ...
> > /usr/local/grass5/etc/set_data: error while loading shared libraries:
> > libtermcap.so.2: cannot open shared object file: No such file or directory
> > jirid at linux:~>
> > Installation under RedHat 7.0 worked fine.  I assume that SUSE 8.1 will
> > install pretty much the same set of libraries.
Please have a look here:
http://grass.itc.it/faq/
-> How to Install
   -> When installing GRASS 5.x Linux binaries I get: error while loading
      shared libraries: libtermcap !
      (http://grass.itc.it/faq/termcap.html)
Cheers
 Markus
