[GRASS5] [bug #1502] (grass) r.mapcalc error
Markus Neteler
neteler at itc.it
Fri Jan 10 12:31:53 EST 2003
On Thu, Jan 09, 2003 at 09:21:17AM +0100, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=1502
> Subject: r.mapcalc error
> Platform: GNU/Linux/i386
> grass obtained from: Trento Italy site
> grass binary for platform: Compiled from Sources
> GRASS 5.0.1(cvs:2003/1/3) compiled under Redhat Linux 7.2
> I found the following bugs(?):
> Error Message: Segmentation Error
> Command : r.mapcalc "crange=@cmax- at cmin"
> cmax(raster) : created by r.statistics command
> base(integer) : include 12737 categoriws
> cover(integer): DEM
> method : max
> cmin(raster) : created by r.statistics command
> base(integer) : include 12737 categoriws(same as cmax)
> cover(integer): DEM
> method : min
> All raster data have 2400x3600 cells with 0.5m resolution under UTM corrdinates.
> Kazukiyo Yamamoto:
> Graduate School of Bioagricultural Sciences
> School of agricultural Sciences
> Nagoya University
The problem appears also for me.
r.mapcalc "test=@map"
Segmentation fault
A fix were great :-)
Markus
