[GRASS5] [bug #1502] (grass) r.mapcalc error
Glynn Clements
glynn.clements at virgin.net
Fri Jan 10 18:16:39 EST 2003
Markus Neteler wrote:
> > I found the following bugs(?):
> > Error Message: Segmentation Error
> > Command : r.mapcalc "crange=@cmax- at cmin"
> The problem appears also for me.
> r.mapcalc "test=@map"
> Segmentation fault
Not for me, unfortunately. Can you reproduce the problem with a map
from one of the sample locations (spearfish, global, etopo5 etc)? If
not, can you provide a *small* location (in terms of file size) which
demonstrates the problem?
Failing that, can you get a backtrace? Either enable core files then
use "gdb -c core" on the resulting core file, or run r.mapcalc under
gdb, e.g.
$ gdb /usr/local/grass5/etc/bin/cmd/r.mapcalc
> run test=@map
> where
Glynn Clements <glynn.clements at virgin.net>
