[GRASS5] [bug #1502] (grass) r.mapcalc error
Markus Neteler neteler at itc.it
Sat Jan 11 11:31:27 EST 2003
On Fri, Jan 10, 2003 at 11:16:39PM +0000, Glynn Clements wrote:
> Markus Neteler wrote:
> > > I found the following bugs(?):
> > > Error Message: Segmentation Error
> > > Command      : r.mapcalc "crange=@cmax- at cmin"
> > The problem appears also for me.
> > r.mapcalc "test=@map"
> > Segmentation fault
> Not for me, unfortunately. Can you reproduce the problem with a map
> from one of the sample locations (spearfish, global, etopo5 etc)? If
> not, can you provide a *small* location (in terms of file size) which
> demonstrates the problem?
> Failing that, can you get a backtrace? Either enable core files then
> use "gdb -c core" on the resulting core file, or run r.mapcalc under
> gdb, e.g.
> 	$ gdb /usr/local/grass5/etc/bin/cmd/r.mapcalc
> 	> run test=@map
> 	> where
I can try that on Monday only. The map "map" was generated with r.in.shape
and contained floating point values as category labels (the category numbers
were the polygon IDs).
Markus
