[GRASS5] g3d success
John Harrop johnh at sjgeophysics.com
Fri Jan 10 20:38:00 EST 2003
I've modified the loops in s.vol.idw and r3.out.v5d to follow the same
pattern:
all loop counters increment.
easting starts in the west and increments.
northing starts in the north and decrements.
level starts at the top and decrements.
When I regrid a 3d site file, and then export it to v5d format, the data
loads into vis5d with all the axes orientationed correctly!  I guess
that shouldn't be too suprising ;-)  I'm getting on to the other modules
as time permits.
Does someone want me send you files, or is that so trivial you can just
make the change?
Cheers,
John Harrop
