[GRASS5] [bug #1555] (grass) r.out.ascii man page typos
Markus Neteler
neteler at itc.it
Thu Jan 30 02:54:09 EST 2003
Thanks, Hamish,
I have fixed it in CVS.
Markus
On Thu, Jan 30, 2003 at 01:16:18AM +0100, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=1555
> Subject: r.out.ascii man page typos
> Platform: GNU/Linux/i386
> grass obtained from: Mirror of Trento site
> grass binary for platform: Compiled from Sources
> found a couple of typos in the r.out.ascii man page:
> Parameters:
> output Name of an output binary file (use output=- for stdout)
> But it isn't a binary file...
> and
> NOTES
> The output from r.out.ascii may be placed into a file by using the UNIX
> redirection mechanism; e.g.: r.out.ascii inout=soils output=- >
> out.file
> Should be input= not inout=
> one little fix at a time..
> Hamish
> -------------------------------------------- Managed by Request Tracker
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Markus Neteler
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
Project on Predictive Models for the Environment
Via Sommarive, 18 - 38050 Povo (Trento), Italy
tel +39 0461 314 520 (fax -591) http://mpa.itc.it
