[GRASS5] Re: [GRASSLIST:5423] is this correct?
Glynn Clements
glynn.clements at virgin.net
Fri Jan 31 17:36:26 EST 2003
Jeff D. Hamann wrote:
> I was attempting to build GRASS from conf_cygwin (the generic?) and the
> build stops here...
> make[1]: *** Deleting file `/cygdrive/n/grass.src/grass5.0.1/dist.i686-pc-cygwin/etc/bin/cmd/m.dem.extract'
> make[1]: *** [/cygdrive/n/grass.src/grass5.0.1/dist.i686-pc-cygwin/etc/bin/cmd/m.dem.extract] Interrupt
> make: *** [do-compile] Interrupt
Something thinks that you explicitly terminated the command (e.g. by
pressing Ctrl-C). If you didn't actually press Ctrl-C, then this is a
problem with Cygwin; there isn't anything that we can do to work
around it.
Try running "make" again (or even repeatedly, until the build actually
completes).
Glynn Clements <glynn.clements at virgin.net>
