[GRASS5] Unofficial Grass 5.0.2 for Debian Woody available
Glynn Clements glynn.clements at virgin.net
Mon Jul 7 13:17:52 EDT 2003
Markus Neteler wrote:
> > Here there's the small fix I made to fix PNGdriver which didn't compile at once:
> > http://ezralabs.esaurito.net/repository/debian/grass/patch-Text2.c
> Should we apply this patch?
> Markus
> --- src/display/devices/lib/Text2.c	Fri Jun 20 17:40:24 2003
> +++ /home/c9/grass-4.99+5.0.0pre4/src/display/devices/lib/Text2.c	Sat
> Feb 16 08:22:57 2002
> @@ -170,11 +170,9 @@
>  	double text_size_x,double text_size_y,double text_rotation,
>  	char *string)
> -double sinrot,cosrot;
> -	//double sinrot = sin (D2R (text_rotation)) ;
> -	//double cosrot = cos (D2R (text_rotation)) ;
> -	sinrot = sin (D2R (text_rotation)) ;
> -	cosrot = cos (D2R (text_rotation)) ;
> +	double sinrot = sin (D2R (text_rotation)) ;
> +	double cosrot = cos (D2R (text_rotation)) ;
>  	am_inside = 0 ;
>  	curx = basex = (double)x ;
>  	cury = basey = (double)y ;
No.
The code already looks like the patched version, so the above patch
won't apply. It's possible that the author reversed the patch; if that
is the case, the patch is bogus.
Glynn Clements <glynn.clements at virgin.net>
