[GRASS5] Re: [GRASSLIST:634] Re: problems with importing LIDAR
Markus Neteler
neteler at itc.it
Wed Jul 9 08:52:05 EDT 2003
On Mon, Jul 07, 2003 at 11:41:21PM +1200, H Bowman wrote:
> > > > s.in.ascii sites=mylidar input=lidar.flt fs=
> > > Either set fs= to something or leave it out.
> > > This is probably a bug, as 's.in.ascii fs=' should take you to the
> > > help page, and it doesn't.
> > Attached a bugfix - could you have a look if you agree with it
> > (strings are not my friends...)?
> I don't know enough C trivia to tell you why a zero-length string is
> !=NULL either, but your patch seems to look & work fine.
OK, I have submitted it to CVS now (should I update the rel branch
as well?).
> I think the problem is more general with "xxxxxx->type = TYPE_STRING;"
> where the parser doesn't fail when the string length is zero.
> e.g., try 's.in.ascii site='
Mhhh, maybe we need a fix in the parser.c file?
> The attached patch (added to yours) cleans that for this specific case,
> but the problem remains maybe in other modules.
> Hamish
> --- main.c.OLD Mon Jul 7 22:37:52 2003
> +++ main.c Mon Jul 7 23:08:46 2003
> @@ -128,9 +128,11 @@
> if (dims<2)
> G_fatal_error ("number of dimensions must be greater than 1");
> - fs = parm.fs->answer;
> - if (fs != NULL)
> + if ( strlen(parm.fs->answer) < 1 )
> + G_fatal_error ("field separator cannot be empty");
> + else
> + fs = parm.fs->answer;
> if(strcmp (fs, "space") == 0)
> fs = NULL;
> else if(strcmp (fs, "tab") == 0)
> @@ -139,11 +141,8 @@
> out_fd = G_fopen_sites_new (output);
> if (out_fd == NULL)
> - fprintf (stderr, " %s - can't create sites file [%s]",
> - me, output);
> - exit(1);
> + G_fatal_error ("can't create sites file [%s].", output);
> G_site_put_head (out_fd, &shead);
> /* G_free(shead.name);
Markus
