[GRASS5] Re: [GRASSLIST:634] Re: problems with importing LIDAR
Glynn Clements
glynn.clements at virgin.net
Wed Jul 9 09:55:19 EDT 2003
Markus Neteler wrote:
> > I think the problem is more general with "xxxxxx->type = TYPE_STRING;"
> > where the parser doesn't fail when the string length is zero.
> > e.g., try 's.in.ascii site='
> Mhhh, maybe we need a fix in the parser.c file?
I don't think so. It's conceivable that some modules may have a valid
use for a string parameter which is allowed to be empty. If a module
doesn't allow an empty string, it should check it itself.
Glynn Clements <glynn.clements at virgin.net>
