[GRASS5] Re: [GRASSLIST:690] Re: undefined symbol pj_get_def in r.gdal.in (grass51cvs)
Radim Blazek
blazek at itc.it
Fri Jul 11 02:48:30 EDT 2003
On Thursday 10 July 2003 16:19, Paul Kelly wrote:
> I don't have too much of an idea about this, but perhaps the above
> directory where your libproj.so is installed isn't in one of the
> directories where your system looks for shared libraries?
> Meaning you would have to add /usr/local/src/proj/src/.libs to your
> LD_LIBRARY_PATH environment variable, or on Linux add it to
> /etc/ld.so.conf and run ldconfig. Or else install PROJ properly so the
> library libproj.so is in one of the standard system directories for shared
> libraries.
> Maybe the GRASS environment should set a special LD_LIBRARY_PATH to take
> care of things like this? I know I needed to set it manually to be able to
> use the GRASS 5.1 shared libraries on IRIX.
But how? Path specified as option for configure? Should not it be used for
compilation only?
Radim
