[GRASS5] GRASS development roadmap proposal
Bernhard Reiter bernhard at intevation.de
Thu Jul 17 10:36:01 EDT 2003
Thanks for the proposal, it is a good idea to work on a roadmap.
On Thu, Jul 17, 2003 at 12:33:43PM +0200, Markus Neteler wrote:
> Users regularly ask (me) about the upcoming GRASS
> releases and their features. To help them and also us
> we should define a roadmap which also solves to some
> extent the versioning problem.
We need to think in development lines
or as I often write series.
Your proposal below is not written to show the development lines.
Certainly we should have 5.0.3 as bug-fix releases.
We might also have further 5.0.x releases which IMO
should also be bug fix releases.
> Two problems have to be addresses:
> - in a 5.0.x version we should not introduce
>   datum transformation as the results will be
>   different
I did not follow the datum discussions in detail.
What do you mean with: The results will be different?
> - we should release datum transformation as soon as
>   possible as it is crucial for GIS data processing.
Another idea would be to make in an experiemental add-on package
to 5.0.x if the datum transformation support is ready for this.
It is clear that the 5.0.x serious has to transform into the
5.1.x serious which then transforms into 5.2.x at some point
where 5.0.x support hopefully can be discontinued.
The renaming part (5.0 HEAD -> 5.3.0 and 5.1.0 -> 5.7.0) suggested
will cause confusion. I advise against it.
> Here a proposal which tries to minimize the version
> naming problems:
> stable                    experimental
> 5.0.2 (current)           5.1.0 (current)
> 5.0.3                     5.3.0 (CVS 5.0 HEAD)
> - bugfixes for 5.0.2      - datum transformation
> - G3D activated           - improved NVIZ
>                           - r.terraflow (C++)
> 5.4.0                     [no more exp development]
> - bugfixes for 5.3.0
>                           5.7.0 (was: 5.1.0 renamed)
>                           - new 2D/3D vector
>                           - DBMS support
>                           - keep sites format [1]
>                           - new Makefile system
>                           - initial cleanup libs
>                           - initial code inline docs
>                             (doxygen)
> 5.8.0                     5.9.0
> - bugfixes for 5.7.0      - eliminate sites [2]
>                           - improve raster format
>                           - improve image processing
> 6.0.0                     6.1.0
> - bugfixes for 5.9.0
> - includes now
>    - new vector
>    - DBMS support
>    - polished libs
>    - inline code docs
>    - improved raster
>    - etc.
> [1] to keep the sites modules for a while seems to be
>     necessary as we do not have the resources to upgrade
>     all sites functionality to vector in short term.
>     No efforts should be invested to improve the sites.
> [2] point data are treated as vector nodes with following
>     advantages:
>     - spatial index for speed, DBMS, NULL support
> Markus
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Professional Service for Free Software                 (intevation.net)
The FreeGIS Project                                       (freegis.org)
Association for a Free Informational Infrastructure          (ffii.org)
FSF Europe                                              (fsfeurope.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20030717/eaf08b9e/attachment.bin
