[GRASS5] GRASS development roadmap proposal
Markus Neteler
neteler at itc.it
Thu Jul 17 11:08:31 EDT 2003
On Thu, Jul 17, 2003 at 04:36:01PM +0200, Bernhard Reiter wrote:
> Thanks for the proposal, it is a good idea to work on a roadmap.
> On Thu, Jul 17, 2003 at 12:33:43PM +0200, Markus Neteler wrote:
> > Users regularly ask (me) about the upcoming GRASS
> > releases and their features. To help them and also us
> > we should define a roadmap which also solves to some
> > extent the versioning problem.
> We need to think in development lines
> or as I often write series.
> Your proposal below is not written to show the development lines.
[Maybe also due to the ASCII limit.]
Line 1: 5.0.x
-> only bugfixes, no new features, almost completed
Line 2: 5.3.x
-> introducing datum transformation, few new features
almost completed, but needs more testing
--> stable will be 5.4.x
Line 3: 5.7.x
-> introducing new vector format etc
work in progress
--> stable will be 5.8.x, leading to 6.x
> Certainly we should have 5.0.3 as bug-fix releases.
> We might also have further 5.0.x releases which IMO
> should also be bug fix releases.
This is what I tried to propose.
> > Two problems have to be addresses:
> > - in a 5.0.x version we should not introduce
> > datum transformation as the results will be
> > different
> I did not follow the datum discussions in detail.
> What do you mean with: The results will be different?
We should not have 5.0.2 without datum transformation and
5.0.3 with datum transformation as the same commands (*.proj)
will end with different results. This means that the maps
are shifted up to some hundred meters. Subversions must
behave the same.
> > - we should release datum transformation as soon as
> > possible as it is crucial for GIS data processing.
> Another idea would be to make in an experiemental add-on package
> to 5.0.x if the datum transformation support is ready for this.
Yes, but with a different version name. Otherwise there will be
too much confusion in the user community ("why is my map
shifted...").
> It is clear that the 5.0.x serious has to transform into the
> 5.1.x serious which then transforms into 5.2.x at some point
> where 5.0.x support hopefully can be discontinued.
In general that the idea.
> The renaming part (5.0 HEAD -> 5.3.0 and 5.1.0 -> 5.7.0) suggested
> will cause confusion. I advise against it.
So please make a better proposal.
Markus
