[GRASS5] GRASS5.1: shapefile import problems
Moritz Lennert
mlennert at club.worldonline.be
Mon Jun 2 17:36:33 EDT 2003
Hello,
I'm trying to use / import a shapefile into 5.1.
When I use v.format, The map seems perfect and d.what.vect displays the
correrct information. However, I seem to be limited to the dbf file as
database since when I use v.db.connect to try to connect the file to a
PostgreSQL database I'm told:
WARNING: Shapefile format cannot be updated.
ERROR: Cannot open old vector cp at mlennert on level 0
When I use v.in.ogr + v.clean (tool=rmdupl,bpol) the file gets imported
incorrectly, areas not being recognized as area and attributes being
linked to the centroids, but not to the areas. I can link this map to the
database, but that doesn't help me with wrong topology.
As info here's v.build output on the v.format shapefile:
v.build cp
WARNING: Topology for shapefile areas is not fully supported.
Registering areas: Topology was built.
Number of nodes : 2511
Number of primitives: 2538
Number of points : 0
Number of lines : 0
Number of boundaries: 1293
Number of centroids : 1245
Number of faces : 0
Number of kernels : 0
Number of areas : 1245
Number of isles : 46
Map is 3D : 0
And here v.build output on the v.in.ogr/v.clean tool=rmdupl,bpol file:
v.build cp_clean
Registering lines:
10696 primitives registered
Building areas: 100%
77 areas built
46 isles built
Attaching islands: 100%
Attaching centroids: 100%
Topology was built.
Number of nodes : 4920
Number of primitives: 10696
Number of lines : 0
Number of boundaries: 9451
Number of faces : 0
Number of areas : 77
Map is 3D : 0
The first one seems correct (I haven't verified for all areas), but the
second is completely wrong.
So, my questions are:
1) can I link a shapefile imported with v.format to a database table ?
2) is there a way I can ensure a more clean import with v.in.ogr
3) knowing that the shape format is very bad, and having access to
ArcView, could I export the file to another format and import it into 5.1
Moritz
