[GRASS5] Towards a 5.1.0 experimental release
Bernhard Reiter bernhard at intevation.de
Fri Jun 6 07:33:52 EDT 2003
Please accept my appologies for not responding to the thread for a while
I was very absorbed due to several reasons.
Nontheless I think we need still need to make progress here.
I'll try to split the subjects in threads to we can
divide and conquer the questions.
My other next action will be to write a small script that
hands out stats on the bug tracker.
	Bernhard
On Sat, May 17, 2003 at 07:23:55PM +0200, Markus Neteler wrote:
> On Sat, May 17, 2003 at 12:13:50AM +0200, Bernhard Reiter wrote:
> > > > We would try to go for a real experimental release (5.1.0) tarball.
> > > > Therefore we should move modules over by procedure to be defined
> > > > and call a freeze on major features for 5.2.
> > > This is the key issue. If the development focus is moved to 5.1, 5.0.x
> > > needs to be frozen; the only subsequent changes to 5.0.x should be bug
> > > fixes.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20030606/b09d1fa7/attachment.bin
