[GRASS5] problem with r.spread
Dirk Dennig
dirk.dennig at gmx.de
Mon Mar 3 02:10:23 EST 2003
Dear community,
I am a new GRASS user. My binary Grass 5.0 was downloaded from the
University Hannover server and is running on Linux Red Hat 8.0. My
computer is a Laptop PC, 256 MB RAM.
The program is running - I did some tutorials and everything worked
fine, except r.spread.
I am using this program to study fire simulations. To learn how all this
is working in GRASS I downloaded the fire simulation package from the
GRASS server. There is a script called firedemo.sh. When I run it, it
gives a segmentation fault, after it passed the r.spread function. This
also happens, when I run only the r.spread program.
I don't know any C yet, so it is very time consuming to find out, where
the problem is. It seems like "replaceHa()" it called a couple of times
and than stops with a seg fault.
I can attach a message from gdb.
100%
Reading inputs ... 100%
Reading fire_origin ... 100%
Finding spread time - number of cells visited in percentage ... 0%(no
debugging symbols found)...(no debugging symbols found)...
Program received signal SIGSEGV, Segmentation fault.
0x0804cd50 in replaceHa ()
I know somebody else trying to work with r.spread as well. She had the
same problem as me. The odd thing is, she said r.spread worked on the
windows port. The windows port is not running on my machine (OS: Windows
2000), but that is another story...
I hope the provided information is sufficient enough to understand my
problem.
Regards,
Dirk
