[GRASS5] Autoconf problems, Grass 5.1 solaris 8 sparc
cheg01 at attbi.com cheg01 at attbi.com
Sun Mar 16 12:39:03 EST 2003
I also get a compile time error when "--with-nls" is used. libgis fails
because of a problem with glocale.h:
make[2]: Entering directory `/usr3/grass51/lib/gis'
gcc -g -Wall  -Wall  -I/usr3/grass51/include -I/usr3/grass51/dist.sparc-sun
-solaris2.8/include      -I/usr3/grass51/include \
            -I/usr3/grass51/dist.sparc-sun-solaris2.8/include \
        -o OBJ.sparc-sun-solaris2.8/adj_cellhd.o -c adj_cellhd.c
adj_cellhd.c: In function `G_adjust_Cell_head':
adj_cellhd.c:44: `PACKAGE' undeclared (first use in this function)
adj_cellhd.c:44: (Each undeclared identifier is reported only once
adj_cellhd.c:44: for each function it appears in.)
adj_cellhd.c: At top level:
/usr3/grass51/include/gis.h:36: warning: `GRASS_copyright' defined but not
used
make[2]: *** [OBJ.sparc-sun-solaris2.8/adj_cellhd.o] Error 1
make[2]: Leaving directory `/usr3/grass51/lib/gis'
make[1]: *** [subdirs] Error 1
make[1]: Leaving directory `/usr3/grass51/lib'
make: *** [default] Error 1
adj_cellhd.c #includes glocale.h, which contains:
extern char * G_gettext(const char *, const char *);
#if defined(HAVE_LIBINTL_H) && defined(USE_NLS)
#include <libintl.h>
#define _(str) G_gettext(PACKAGE,(str))
#else
#define _(str) (str)
#endif
Looks like PACKAGE is supposed to be #defined somewhere but it is not.The
variable PACKAGE is used quite extensively in Grass5.0.1 makefiles but it
does not appear anywhere else in the 5.1 code.
