[GRASS5] Error building 5.1 CVS head on Solaris 8 sparc <solved>
cheg01 at attbi.com cheg01 at attbi.com
Mon Mar 17 00:58:08 EST 2003
> ----- Original Message -----
> From: "Radim Blazek" <blazek at itc.it>
> To: <cheg01 at attbi.com>
> Cc: "grass5 developers list" <grass5 at grass.itc.it>
> Sent: Thursday, March 13, 2003 12:32 AM
> Subject: Re: [GRASS5] Error building 5.1 CVS head on Solaris 8 sparc
 > On Thursday 13 March 2003 08:41 am, you wrote:
> I'm getting the following error during "make" in the latest 5.1 CVS head:
> make: *** No rule to make target `OBJ.sparc-sun-solaris2.8/area.o',
needed
> by `/usr3/grass51/dist.sparc-sun-solaris2.8/lib/libvect.a'. Stop.
> I get this error if I try to compile vectlib (Vlib) as first
> in clean tree. Some other libraries must be compiled first:
> gislib (lib/gis)
> shapelib (lib/external/shapelib)
> diglib (lib/vector/diglib)
> dglib (lib/vector/dglib)
> rtreelib (lib/vector/rtree)
> Radim
In order to complete a build of grass51 CVS head on Solaris 8 Sparc I had
to make the following changes:
1) Remove "$(SOCKLIB) $(INTLLIB)" from the definition of GISLIB in
Grass.make.in. This was causing the "No rulle to make target" errors.
2) Change "test-e" to "test -x" in 2 places in /vector/v.ascii/Makefile.
3) Change the definition of "PQLIB" in Platform.make from "-lpq" to
"-lresolv".
I also had to add the full path to libpq.a since it is not in a default
library path in my systme. I added it to PQLIB because I did not know how
else to do it. I am running configure with the "--with-postgres-includes="
and "--with-postgres-libs=" options but the path to the library does not
show up in the make files for some reason.
