[GRASS5] 5.1 execution
cheg01 at attbi.com
cheg01 at attbi.com
Mon Mar 17 02:07:25 EST 2003
I have 5.1 running on Solaris 8 Sparc but none of the functions are
working. I can get the interface windows to run but all of them produce the
following error trace when I try to run a function:
can't read "opttype(1)": no such element in array
while executing
"if { $opttype($i) == "multi" } {
set domulti 0
for {set j 1} {$j <= $nmulti($i) } {incr j} {
if { $optval($i,$..."
(procedure "mkcmd" line 5)
invoked from within
"mkcmd "
invoked from within
".run invoke"
("uplevel" body line 1)
invoked from within
"uplevel #0 [list $w invoke]"
(procedure "tkButtonUp" line 7)
invoked from within
"tkButtonUp .run
(command bound to event)
Is it possible to run the 5.1 functions from the command line through a
parser like in 5.0?
