[GRASS5] 5.1 execution
Radim Blazek blazek at itc.it
Mon Mar 17 04:45:06 EST 2003
You can run modules with specified options and flags as in
5.0, GUI is opened only if module is run without any option.
To get old text interface you need to set enviroment variable
(not GRASS variable) GRASS_UI_TERM
(for example in bash: export GRASS_UI_TERM=1)
Radim
On Monday 17 March 2003 08:07 am, cheg01 at attbi.com wrote:
> I have 5.1 running on Solaris 8 Sparc but none of the functions are
> working. I can get the interface windows to run but all of them produce the
> following error trace  when I try to run a function:
> can't read "opttype(1)": no such element in array
>     while executing
> "if { $opttype($i) == "multi" } {
>             set domulti 0
>             for {set j 1} {$j <= $nmulti($i) } {incr j} {
>                 if { $optval($i,$..."
>     (procedure "mkcmd" line 5)
>     invoked from within
> "mkcmd "
>     invoked from within
> ".run invoke"
>     ("uplevel" body line 1)
>     invoked from within
> "uplevel #0 [list $w invoke]"
>     (procedure "tkButtonUp" line 7)
>     invoked from within
> "tkButtonUp .run
>     (command bound to event)
> Is it possible to run the 5.1 functions from the command line through a
> parser like in 5.0?
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
