[GRASS5] [bug #1758] (grass) d.vect.area: linecolor= should default to 'none'
Request Tracker
grass-bugs at intevation.de
Mon Mar 24 05:21:41 EST 2003
this bug's URL: http://intevation.de/rt/webrt?serial_num=1758
Subject: d.vect.area: linecolor= should default to 'none'
Platform: GNU/Linux/i386
grass obtained from: Mirror of Trento site
grass binary for platform: Compiled from Sources
GRASS Version: 5.0.0
d.vect.area uses a default linecolor= of black, which doesn't look good (artificially subtractive) unless you have specifically used "d.erase color=xxxx" first. It should instead default to 'none', which happens to be faster as well.
Yes? No?
Hamish
-------------------------------------------- Managed by Request Tracker
