[GRASS5] [bug #1853] (grass) v.in.shape
Request Tracker grass-bugs at intevation.de
Thu May 8 08:43:14 EDT 2003
this bug's URL: http://intevation.de/rt/webrt?serial_num=1853
Subject: v.in.shape
grass binary for platform: Compiled from Sources
There is a bug in v.in.shape: It doesn't import a file containing
two dots:
GRASS:~/test > v.in.shape 528011.PL.shp
WARNING: Log file not specified. Sending messages to 'standard error'
Couldn't open input file. You did not supply a full path in the input name.
Could that be an error?
FATAL ERROR: There was a problem importing the map.
Then I renamed the file to contain only 1 dot and the import was
successfull:
GRASS:~/test > v.in.shape 528011.shp
File `528011.shp' is of Type Line (Arc) with 488 entries.
Bounds:
W:     -121.500012, E:     -121.249978, S:       38.499988, N:       38.750010.
Map `528011' imported, apparently without problems.
Markus
-------------------------------------------- Managed by Request Tracker
