[GRASS5] GRASS 5.1 v.in.ascii bug
Radim Blazek
blazek at itc.it
Thu May 8 11:46:56 EDT 2003
On Thursday 08 May 2003 11:40 am, GFernandez-Victorio at IGAE.minhac.es wrote:
> > int main( int argc, char **argv ) {
> > int i, a, x;
> > a = rand();
> > if ( a ) {
> > i = 1;
> > x = 0;
> > } else {
> > i = 0;
> > if ( i ) printf ("%d\n", x);
> > exit (0);
> > gcc -Wall prints: warning: `x' might be used uninitialized in
> > this function
> > IMHO it may not be used uninitialized. Am I missing something?
> > Please explain this to me.
> > Simply add x=0; at the beginning to avoid this warning doesn't
> > seem to be correct.
> Radim. Maybe I'm missing something, but, what do you expect from 'x'
> in the else case?. What is the purpouse of 'x' variable in general?
It was just a test what that warning means - explained by Glynn.
Radim
