[GRASS5] v.in.dwg license problem
Russell Nelson nelson at crynwr.com
Fri May 16 14:02:58 EDT 2003
Radim Blazek writes:
 > Open DWG license gives more freedom to distribute v.in.dwg for free than GPL.
If that was the case, then there would be no problem.  It is decidedly
not the case, though.  The GPL allows for commercial distribution, the
Open DWG license does not.  The GPL requires source distribution, and
the Open DWG library doesn't come with source, and even if you pay
$25,000, you still can't distribute the source.
--My blog is at angry-economist.russnelson.com  | "I have officially heard
Crynwr sells support for free software  | PGPok | every excuse for being
521 Pleasant Valley Rd. | +1 315 268 1925 voice | assigned a single room at
Potsdam, NY 13676-3213  | +1 315 268 9201 FAX   | FGC."  --Liz Perch
