[GRASS5] g51: r.coin compile error
Stephan Holl sholl at gmx.net
Wed May 21 07:52:48 EDT 2003
Dear developers,
does anybody of you know what this error is meant to be?
Compilation of G51 stops at r.coin with the following error.
GRASS_FAKE_START=1
GISBASE=/daten/software/grass51/dist.i686-pc-linux-gnu
/daten/software/grass51/dist.i686-pc-linux-gnu/etc/bin/cmd/r.coin
--html-description | grep -v '</body>' > r.coin.html ; true
ERROR: MAPSET fakestart not found
echo "<HR>" >> r.coin.html
echo "<P><a href=index.html>Help Index</a>" >> r.coin.html
echo "</body></html>" >> r.coin.html
mkdir -p /daten/software/grass51/dist.i686-pc-linux-gnu/docs/html
mv r.coin.html /daten/software/grass51/dist.i686-pc-linux-gnu/docs/html
gcc  -L/daten/software/grass51/dist.i686-pc-linux-gnu/lib    cmd.o
htmlcmd   -o cmd
gcc: htmlcmd: Datei oder Verzeichnis nicht gefunden
make[2]: *** [cmd] Fehler 1
make[2]: Verlassen des Verzeichnisses
/daten/software/grass51/raster/r.coin
make[1]: *** [subdirs] Fehler 1
make[1]: Verlassen des Verzeichnisses /daten/software/grass51/raster
make: *** [default] Fehler 1
I am unable to solve this, but it seems to come from the the
GRASS_FAKE_START-variable, which worked OK with other modules...(all
other previously built)
Thanks for investigating that.
cheers
Stephan Holl
GnuPG Key-ID: 11946A09
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20030521/a2d35161/attachment.bin
