[GRASS5] Re: GRASS 5.1 compile error
Martin Pokorny
martin at truffulatree.org
Wed May 21 13:39:48 EDT 2003
On Wed, 21 May 2003, GFernandez-Victorio at igae.minhac.es wrote:
>> > gcc -g -Wall -Wall -I/data/GRASSCVS/grass51/include
>> > -I/data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/include
>> > -I/data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/include \ -o
>> > OBJ.i686-pc-linux-gnu/lex.yy.o -c lex.yy.c lex.l: In function
>> > `yyerror': lex.l:235: `YY_FLUSH_BUFFER' undeclared (first use in
>> > this function) lex.l:235: (Each undeclared identifier is reported
>> > only once lex.l:235: for each function it appears in.) lex.l: At
>> > top level:
>> Moritz.
>> I had the same problem a few weeks ago. I found at Google that it
>> seems to be related to an ancient bug in flex.
> As a followup:
> I've found that current flex version is 2.5.31 in:
> http://sourceforge.net/projects/lex/
> This is the one being distributed with Debian Unstable. When using
> the version included with Debian, I get the same error of Moritz.
I also encountered this same problem yesterday on my Debian system. I
found a way around the problem by modifying lib/db/sqlp/lex.l from
CVS. It turns out that the lex.yy.c file generated from lex.l defines
'YY_FLUSH_BUFFER' at one point, and then undefines it later on, before
its use in the 'yyerror' function. I just manually expanded the macro
in lex.l, and now all is well AFAICT. I'm too lazy right now to
produce a diff, but here's a copy of my lex.l---look around line 233,
I've commented out the original, and inserted my one line
modification.
* MODULE: SQL statement parser library
* AUTHOR(S): lex.l and yac.y were originaly taken from unixODBC and
* probably written by Peter Harvey <pharvey at codebydesigns.com>,
* modifications and other code by Radim Blazek
* PURPOSE: Parse input string containing SQL statement to
* SQLPSTMT structure.
* SQL parser may be used by simple database drivers.
* COPYRIGHT: (C) 2000 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
* for details.
/**************** C-CODE *****************/
#include "sqlp.h"
#include "y.tab.h"
#include <string.h>
#undef YY_INPUT
#define YY_INPUT(b, r, ms) (r = my_yyinput(b, ms))
/*************** LEX HEADER **************/
%e 1200
/**************** LEX BODY ****************/
* LITERALS KEYWORDS TOKENS
/* following case insensitives are ugly
but I do not know better at this time */
[Dd][Ee][Ll][Ee][Tt][Ee] { return DELETE; }
[Ff][Rr][Oo][Mm] { return FROM; }
[Ii][Nn][Ss][Ee][Rr][Tt] { return INSERT; }
[Ii][Nn][Tt][Oo] { return INTO; }
[Ss][Ee][Ll][Ee][Cc][Tt] { return SELECT; }
[Ss][Ee][Tt] { return SET; }
[Uu][Pp][Dd][Aa][Tt][Ee] { return UPDATE; }
[Vv][Aa][Ll][Uu][Ee][Ss] { return VALUES; }
[Ww][Hh][Ee][Rr][Ee] { return WHERE; }
[Aa][Nn][Dd] { return AND; }
[Cc][Rr][Ee][Aa][Tt][Ee] { return CREATE; }
[Dd][Rr][Oo][Pp] { return DROP; }
[Tt][Aa][Bb][Ll][Ee] { return TABLE; }
[Vv][Aa][Rr][Cc][Hh][Aa][Rr] { return VARCHAR; }
[Ii][Nn][Tt] { return INT; }
[Ii][Nn][Tt][Ee][Gg][Ee][Rr] { return INTEGER; }
[Dd][Oo][Uu][Bb][Ll][Ee] { return DOUBLE; }
[Pp][Rr][Ee][Cc][Ii][Ss][Ii][Oo][Nn] { return PRECISION; }
[Oo][Rr] { return OR; }
[Nn][Oo][Tt] { return NOT; }
/* [Dd][Ii][Ss][Tt][Ii][Nn][Cc][Tt] { return DISTINCT; } */
* EQUAL
return EQUAL;
* COMPARISON
yylval.strval = (char*)strdup(yytext);
return COMPARISON;
* PUNCTUATION
return yytext[0];
* NAMES
[A-Za-z][A-Za-z0-9_]* {
return NAME;
* INTEGER
[+-]?[0-9]+ {
yylval.intval = atoi(yytext);
/* yylval.strval = (char*)strdup(yytext); */
return INTNUM;
* FLOATING POINT NUM
"."[0-9]* |
[+-]?[0-9]+"."[0-9]* |
[+-]?[0-9]+[eE][+-]?[0-9]+ |
[+-]?[0-9]+"."[0-9]*[eE][+-]?[0-9]+ |
"."[0-9]*[eE][+-]?[0-9]+ {
yylval.floatval = atof(yytext);
return FLOATNUM;
* STRINGS (single quotes)
'[^'\n]*' {
char *Buffer, *ptra, *ptrb;
int c = input();
int len;
Buffer = (char*)strdup(yytext); /* store here because we lose it when unput() */
unput( c ); /* just peeking - checking for a double quote... embedded quote */
if ( c != '\'' )
len = strlen (Buffer);
Buffer[len-1] = '\0';
/* Hopefully replace all '' by ' */
ptrb = Buffer + 1;
while ( (ptra = strchr(ptrb, '\'')) != NULL ) {
ptra++; ptrb = ptra;
while ( ptra[1] != 0 ) { ptra[0] = ptra[1]; ptra++; }
ptra[0] = 0;
yylval.strval = (char*)strdup(Buffer+1);
free( Buffer );
return STRING;
else
free( Buffer );
yymore();
* STRINGS (unterminated)
'[^'\n]*$ { yyerror("Unterminated string"); }
* NEW LINE (ignored)
\n ;
* WHITE SPACE (ignored)
[ \t\r]+ ; /* white space */
* COMMENTS (ignored)
"--".*$ ; /* comment */
* C-CODE
* my_yyinput
* Lexer will ask this function for input when it requires more.
int my_yyinput(char *buf, int max_size)
int rest, n;
rest = sqlpStmt->stmt + strlen( sqlpStmt->stmt) - sqlpStmt->cur;
n = ( max_size < rest ? max_size : rest );
if ( n > 0 )
memcpy( buf, sqlpStmt->cur, n );
sqlpStmt->cur += n;
return n;
* yyerror
* This should be called just before failing. It formats a meaningfull
* message and deposits it in a usefull place.
void yyerror( char *s )
snprintf( sqlpStmt->errmsg, 500, "%s processing '%s'", s, yytext );
yy_flush_buffer(YY_CURRENT_BUFFER);
/* YY_FLUSH_BUFFER; */
* yywrap
* We are not doing any buffer switching but lets not use the Flex version of
* of this func anyway so we can avoid the link dependency.
int yywrap()
return 1;
Martin Pokorny
Tucson, AZ, USA
