[GRASS5] g51: r.coin compile error
Stephan Holl sholl at gmx.net
Thu May 22 04:17:00 EDT 2003
At Wed, 21 May 2003 14:15:00 +0200 Markus Neteler wrote:
Markus,
> This indicates that 5.0 and 5.1 are not in sync (I have fixed above
> problem a week ago or so).
> To do:
> - 5.1: make mixclean
> - 5.0: update r.coin from CVS
> - 5.1: make mix
> - 5.1: recompile
after following your instructions I sill cannot manage g51 to compile
correct.
the same error is still existent.
the folder r.coin ist up-tp-date, as indicated by cvs
cvs status  src/raster/r.coin/
cvs server: Examining src/raster/r.coin/
File: Gmakefile         Status: Up-to-date
   Working revision:    1.1.1.1
   Repository revision: 1.1.1.1
/home/grass/grassrepository/grass/src/raster/r.coin/Gmakefile,v
   Sticky Tag:          HEAD (revision: 1.1.1.1)
   Sticky Date:         (none)
   Sticky Options:      (none)
[snip]....
...but compilation still fails.
sorry for any inconvenience
cheers
  Stephan
Stephan Holl
GnuPG Key-ID: 11946A09
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20030522/b3a02859/attachment.bin
