[GRASS5] g51: r.coin compile error
Markus Neteler
neteler at itc.it
Thu May 22 04:40:09 EDT 2003
On Thu, May 22, 2003 at 10:17:00AM +0200, Stephan Holl wrote:
> At Wed, 21 May 2003 14:15:00 +0200 Markus Neteler wrote:
> Markus,
> > This indicates that 5.0 and 5.1 are not in sync (I have fixed above
> > problem a week ago or so).
> > To do:
> > - 5.1: make mixclean
> > - 5.0: update r.coin from CVS
> > - 5.1: make mix
> > - 5.1: recompile
> after following your instructions I sill cannot manage g51 to compile
> correct.
> the same error is still existent.
> the folder r.coin ist up-tp-date, as indicated by cvs
> cvs status src/raster/r.coin/
> cvs server: Examining src/raster/r.coin/
> File: Gmakefile Status: Up-to-date
> Working revision: 1.1.1.1
> Repository revision: 1.1.1.1
> /home/grass/grassrepository/grass/src/raster/r.coin/Gmakefile,v
> Sticky Tag: HEAD (revision: 1.1.1.1)
> Sticky Date: (none)
> Sticky Options: (none)
> [snip]....
> ...but compilation still fails.
> sorry for any inconvenience
Stephan:
cd grass51/
cd src/raster/r.coin/
-> remove all links to 5.0 here
cd grass50
cd src/raster/r.coin/cmd/
-> there should be the files:
check.c CVS inter.c make_coin.c print_hdr.c
cmd_parms.c format.c local_proto.h OBJ.i686-pc-linux-gnu prnt_entry.c
coin.h Gmakefile main.c print_coin.c totals.c
(note: not cmd.c but cmd_parms.c etc)
If not, update here.
cd grass51/
make mix
-> check that cmd.c is not there but cmd_parms.c
Then it should compile. At some point your system seems not to be
up-to-date.
Good luck
Markus
