[GRASS5] xwininfo error on Mac OS X
    Glynn Clements
    glynn.clements at virgin.net
    Tue May 27 00:32:01 EDT 2003
Nik Sands wrote:
> I'm new to GRASS and am having some trouble getting it to run on Mac OS
> X.
> I've installed TclTkAqua-8.4.2, and grass5.0.2 successfully, and can
> start GRASS okay.
> However, when I enter the "tcltkgrass &" command, I get the following
> output:
> Error in startup script: xwininfo: error: No such window with id
> 0xec0f08.
>      while executing
> "exec xwininfo -id [winfo id .w_g] | grep -i Corners"
"tcltkgrass" is written for a Unix/X11 version of Tcl/Tk; using it
with other versions of Tcl/Tk will result in errors.
In this particular case, tcltkgrass expects "winfo id ..." to return
the ID of an X window (which it does with a Unix/X11 version of
Tcl/Tk).
Glynn Clements <glynn.clements at virgin.net>
