[GRASS5] Re: Oups! Problem in CVS
    Thierry Laronde
    tlaronde at polynum.com
    Tue Nov  4 06:12:37 EST 2003
Better with the file...
On Tue, Nov 04, 2003 at 11:55:31AM +0100, Thierry Laronde wrote:
> Hello,
> I have synchronised with CVS and my patches for pg.in.dbf have not
> applied cleanly. The present version in CVS can not compile.
> You will find attached to this mail the plain versions (not patches)
> which seems the best solution to put the CVS version up again.
> There are also in CVS files .#* which have to be removed.
> Note: when I made the patches I had no high bandwith connection so I
> have retrieved the snapshot. Problems might have came from that.
> I have no a high bandwith connection, so I will work with CVS directly
> from now on.
> Regards,
> Thierry Laronde (Alceste) <tlaronde at polynum.org>
> Key fingerprint = 0FF7 E906 FBAF FE95 FD89  250D 52B1 AE95 6006 F40C
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20031104/3cdf76c8/pg.in.dbf.tar.obj
