[GRASS5] Grass 5 new releases
Markus Neteler neteler at itc.it
Mon Nov 10 10:55:05 EST 2003
Hi Jens,
FINK is quite behind at time (PROJ is missing, GDAL seem to be incomplete
(no OGR), GRASS seems to be deleted):
http://fink.sourceforge.net/pdb/search.php?s=proj
http://fink.sourceforge.net/pdb/search.php?s=gdal
http://fink.sourceforge.net/pdb/search.php?s=grass
BUT:
You can find all three packages for MacOSX here:
http://mpa.itc.it/markus/grass57/macosx/
But I am not updating it regularly.
Drawback: due to circular dependencies in XDRIVER I had to compile
it statically. So it's large. Unless someone fixes the XDRIVER
(see 'grass5' archive for error message) it won't be usage with
dynamic libs on MacOSX.
Cheers
 Markus
On Mon, Nov 10, 2003 at 03:00:01PM +0100, Jens Oberender wrote:
> Hi
> On Sun, 9 Nov 2003 13:27:00 -0500 (EST)
> Scott W Mitchell <smitch at mac.com> wrote:
> > I'm interested in helping too.  I made a binary distribution once > before, and using instructions from Markus, it created that script
> > "automatically", so that shouldn't be an issue.  I'll forward you an > email I have from those days in a minute.  In short, there were two > ways:  (1) follow the directions in the > documentation/release_rules.txt under the main source directory, and > (2) Markus has a script that he uses to get through all the steps in > the release_rules... but unless there are new developments, this > script is not completely portable.  On the other hand, it didn't take > TOO much modification to make it work for me on my system, and it > helped make sure I was making binaries the same way as Markus.
> Perhaps you can use fink (http://fink.sourceforge.net) to provide complete grass binary packages.
> Fink is like the debian package manager (apt-get) and there for very powerfull, as it can check dependencies and download the needed packages too.
> Fink already provides 2500 open source packages for MacOSX.
> A user would just have to do a
> apt-get install grass
> And that would download all dependent packates and install them for him.
> Just my 2 cents.
> Bye,
> 	Jens Oberender
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Markus Neteler     <neteler at itc.it>       http://mpa.itc.it
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
