[GRASS5] NVIZ updates
Helena hmitaso at unity.ncsu.edu
Thu Nov 13 20:44:19 EST 2003
Bob,
I updated my CVS GRASS with your nviz updates and nviz crashes
when I give it an elevation file - either on the command line or
through the interface - when it is computing the normals.
It runs OK if I open it as nviz -q and give it just a constant (plane) surface.
I will try with some other data, but maybe somebody else could try it too
to see whether it is my data or a bug. (the data worked fine with the previous
version of nviz).
Also, how do you have this linked with GRASS5.7 - are you maintaining two separate versions?
thank you,
Helena
Loading Data
Loading Data
translating colors from fp
global-exag = 1.000000
recalculating normals...
100
200
child killed: segmentation violation
     while executing
"exec /home/helena/grasscvs53/grass5/etc/nviz2.2/NVWISH2.2 -f /home/helena/grasscvs53/grass5/etc/nviz2.2/scripts/nviz2.2_script -q -name NVIZ >&@stdout"
     ("eval" body line 1)
     invoked from within
"eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script $argv -name NVIZ >&@stdout"
     invoked from within
"if {$argv == ""} {
#no arguments
eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdo..."
     (file "/home/helena/grasscvs53/grass5/bin/nviz" line 16)
  The error message Bob Covill wrote:
> Hello,
> I have applied a few updates / bug fixes to the ogsf library and NVIZ.
> The updates / fixes include the following:
> 1. I have optimized the surface rendering routine to use a TRIANGLE_FAN
> along with a few other optimizations. In the tests I ran this improved
> surface drawing time by about a factor of four. This of course depends
> upon the surface being renderred and the zoom level.
> 2. I have added a new wire frame option (now the default) that draws a
> sub-sampled (coarse) surface instead of the wire. To accomadate this I
> have re-arranged the surface panel and added the drawing options as
> pull-down menus. There is now a pull-down menu for the old "Surface
> Style" and "Shading" options plus the new option for "Grid Style". Under
> "Grid Style" the user may now select to draw the coarse surface or the
> old wire surface. In reference to the new coarse surface, the resolution
> is controlled by the "Grid Resolution" number. This number represents
> the sub-sampling ratio of the current surface. A Grid Resolution of 1
> would draw every (identical) full surface pixel. A Grid Resolution of 2
> would draw every second pixel, and so on. This new drawing routine also
> allows animations to run in this coarse mode.
> 3. I have added a new "position" panel to the available panels list
> (under Panel). This new panel allows the user to manually enter the
> center and eye positions (XYZ) in real coordinates and apply them. There
> is also an available Range/Bearing section that allows the user to set a
> range and bearing to either the cente or eye positions.
> To use the menu select the Refresh button to update each entry box to
> the current position. To apply newly entered coordinates and and update
> the GUI select the Apply button. To use the Range/Bearing options select
> the Refesh button (if not already selected), and choose the appropriate
> reference radiobutton. The options are to apply range and bearing to
> "Eye to Surface" which moves the view center while leaving the eye
> position unchanged or "Surface to Eye" which changes the eye position
> while leaving the center position unchanged. The second "Surface to Eye"
> option is alittle easier to use as you are less likly to move the
> surface completely out of view. After choosing the appropriate reference
> enter a new Range, Bearing (in degrees) and Elevation (in degrees). The
> elevation sets the angle you are looking down at the surface. After
> entering the new values select Calculate to generate the new coordinates
> and Apply to the apply new coordinates.
> This new menu will probably need further updating / debugging.
> 4. I have fixed a couple of bugs in the kanimator panel where the new
> key time was not being set correctly and duplicate key tags were not
> being weeded out. The duplicate key tags led to unpredictable behavious
> in the kanimator GUI.
> If you have any questions or problems with the above updates please let
> know.
