[GRASS5] NVIZ updates
Helena hmitaso at unity.ncsu.edu
Thu Nov 13 20:54:40 EST 2003
I should have done more before writing - it runs OK with Spearfish
and the new option with coarse rendered grid is realy,realy nice.
So I will try to find out why it crashes with the other data, maybe others can try too.
Helena
Helena wrote:
> Bob,
> I updated my CVS GRASS with your nviz updates and nviz crashes
> when I give it an elevation file - either on the command line or
> through the interface - when it is computing the normals.
> It runs OK if I open it as nviz -q and give it just a constant (plane)
> surface.
> I will try with some other data, but maybe somebody else could try it too
> to see whether it is my data or a bug. (the data worked fine with the
> previous
> version of nviz).
> Also, how do you have this linked with GRASS5.7 - are you maintaining
> two separate versions?
> thank you,
> Helena
> Loading Data
> Loading Data
> translating colors from fp
> global-exag = 1.000000
> recalculating normals...
> 100
> 200
> child killed: segmentation violation
>     while executing
> "exec /home/helena/grasscvs53/grass5/etc/nviz2.2/NVWISH2.2 -f
> /home/helena/grasscvs53/grass5/etc/nviz2.2/scripts/nviz2.2_script -q
> -name NVIZ >&@stdout"
>     ("eval" body line 1)
>     invoked from within
> "eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f
> $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script $argv -name NVIZ
>  >&@stdout"
>     invoked from within
> "if {$argv == ""} {
> #no arguments
> $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdo..."
>     (file "/home/helena/grasscvs53/grass5/bin/nviz" line 16)
>  The error message Bob Covill wrote:
>> Hello,
>> I have applied a few updates / bug fixes to the ogsf library and NVIZ.
>> The updates / fixes include the following:
>> 1. I have optimized the surface rendering routine to use a
>> TRIANGLE_FAN along with a few other optimizations. In the tests I ran
>> this improved surface drawing time by about a factor of four. This of
>> course depends upon the surface being renderred and the zoom level.
>> 2. I have added a new wire frame option (now the default) that draws a
>> sub-sampled (coarse) surface instead of the wire. To accomadate this I
>> have re-arranged the surface panel and added the drawing options as
>> pull-down menus. There is now a pull-down menu for the old "Surface
>> Style" and "Shading" options plus the new option for "Grid Style".
>> Under "Grid Style" the user may now select to draw the coarse surface
>> or the old wire surface. In reference to the new coarse surface, the
>> resolution is controlled by the "Grid Resolution" number. This number
>> represents the sub-sampling ratio of the current surface. A Grid
>> Resolution of 1 would draw every (identical) full surface pixel. A
>> Grid Resolution of 2 would draw every second pixel, and so on. This
>> new drawing routine also allows animations to run in this coarse mode.
>> 3. I have added a new "position" panel to the available panels list
>> (under Panel). This new panel allows the user to manually enter the
>> center and eye positions (XYZ) in real coordinates and apply them.
>> There is also an available Range/Bearing section that allows the user
>> to set a range and bearing to either the cente or eye positions.
>> To use the menu select the Refresh button to update each entry box to
>> the current position. To apply newly entered coordinates and and
>> update the GUI select the Apply button. To use the Range/Bearing
>> options select the Refesh button (if not already selected), and choose
>> the appropriate reference radiobutton. The options are to apply range
>> and bearing to "Eye to Surface" which moves the view center while
>> leaving the eye position unchanged or "Surface to Eye" which changes
>> the eye position while leaving the center position unchanged. The
>> second "Surface to Eye" option is alittle easier to use as you are
>> less likly to move the surface completely out of view. After choosing
>> the appropriate reference enter a new Range, Bearing (in degrees) and
>> Elevation (in degrees). The elevation sets the angle you are looking
>> down at the surface. After entering the new values select Calculate to
>> generate the new coordinates and Apply to the apply new coordinates.
>> This new menu will probably need further updating / debugging.
>> 4. I have fixed a couple of bugs in the kanimator panel where the new
>> key time was not being set correctly and duplicate key tags were not
>> being weeded out. The duplicate key tags led to unpredictable
>> behavious in the kanimator GUI.
>> If you have any questions or problems with the above updates please
>> let know.
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
