[GRASS5] GRASS5.7: compile error: " No rule to make target
 `OBJ.i686-pc-linux-gnu/get_proj.o"
    Moritz Lennert
    mlennert at club.worldonline.be
    Fri Nov 14 12:10:51 EST 2003
Hello,
Trying to compile 5.7 from todays CVS I get the following error:
make[2]: Entering directory `/data/GRASSCVS/grass51/lib/proj'
make[2]: *** No rule to make target `OBJ.i686-pc-linux-gnu/get_proj.o',
needed b
y `/data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/lib/libgrass_gproj.so'.
Stop.
make[2]: Leaving directory `/data/GRASSCVS/grass51/lib/proj'
make[1]: *** [subdirs] Error 1
I use Debian testing with proj (debian) version 4.4.7-3.
Is this a problem in the Makefile, or somewhere else ?
Moritz
