[GRASS5] GRASS5.7: compile error: " No rule to make
     target`OBJ.i686-pc-linux-gnu/get_proj.o"
    Moritz Lennert
    mlennert at club.worldonline.be
    Mon Nov 17 10:02:35 EST 2003
Replying to myself as a follow-up:
Moritz Lennert said:
> Hello,
> Trying to compile 5.7 from todays CVS I get the following error:
> make[2]: Entering directory `/data/GRASSCVS/grass51/lib/proj'
> make[2]: *** No rule to make target `OBJ.i686-pc-linux-gnu/get_proj.o',
> needed b
> y `/data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/lib/libgrass_gproj.so'.
> Stop.
> make[2]: Leaving directory `/data/GRASSCVS/grass51/lib/proj'
> make[1]: *** [subdirs] Error 1
I got it to compile by linking to get_proj.c and do_proj.c in the GRASS5.3
directory /src/libes/proj.
Is this the correct solution and make mix should create these links or am
I on the wrong path ?
Moritz
