[GRASS5] GRASS5.7: compile error: " No rule to make
 target`OBJ.i686-pc-linux-gnu/get_proj.o"
    Paul Kelly
    paul-grass at stjohnspoint.co.uk
    Mon Nov 17 10:18:19 EST 2003
Hello Moritz
On Mon, 17 Nov 2003, Moritz Lennert wrote:
> > make[2]: *** No rule to make target `OBJ.i686-pc-linux-gnu/get_proj.o',
> > needed b
> > y `/data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/lib/libgrass_gproj.so'.
> > Stop.
> > make[2]: Leaving directory `/data/GRASSCVS/grass51/lib/proj'
> > make[1]: *** [subdirs] Error 1
> I got it to compile by linking to get_proj.c and do_proj.c in the GRASS5.3
> directory /src/libes/proj.
> Is this the correct solution and make mix should create these links or am
> I on the wrong path ?
Those files now exist in the 5.7 CVS and are slightly different from the
5.3 versions. If you make sure any old 'make mix' links are deleted and
run cvs update they should appear; if not I don't know what's wrong.
Paul
