[GRASS5] NVIZ updates
Bob Covill bcovill at tekmap.ns.ca
Sat Nov 15 19:15:58 EST 2003
Helena,
I have applied a fix to CVS that corrects (hopefully) the NVIZ bug you
reported.
The problem was with surfaces being loaded that contained no null values
.  The new coarse surface (wire) routine was causing a crash. Apparently
if a null mask is created it is much more forgiving if one isn't (i.e.
no nulls).
The fixed gsd_wire.c in src/libes/ogsf should correct the bug.
To test update your ogsf and rebuild NVIZ.
Let me know if you encounter any more problems, etc.
Thanks for catching this.
Bob Covill
