[GRASS5] i.points and i.rectify question
Bob Covill
bcovill at tekmap.ns.ca
Sun Nov 16 19:31:42 EST 2003
Hello,
There is a difference between i.rectify (& i.points) and i.rectify3.
Unfortunately, I have never figured out which one is "more" correct. I
think that i.rectify3 post dates i.rectify and was intended to replace it??
The i.rectify3 and i.points3 programs both use the image3 library in
src/libes. This library utilizes the proj library and converts
coordinates on the fly between lat. long. and the users coordinate
system. Unfortunately, i.rectify3 is not built by default, but the
source is still there.
We probably need to decide which set of programs is more up to date (and
accurate). My preference has been i.points3 and i.rectify3 but I may be
way off on this.
Bob Covill
Michael Barton wrote:
> In versions 5.0.x and 5.3 are the 2 modules i.points and i.points3. The
> documentation for both versions of GRASS discuss the associated programs
> i.rectify and i.rectify3. However, there does not seem to be a module
> i.rectify3 anywhere. Some months back, before I realized that i.rectify3
> was missing, I tried both i.points and i.points3 and found i.points3 to
> be a better program in several respects. However, the output file it
> creates (image xy and georeferenced coordinate pairs) seems to be ONLY
> in lat long and does not work with i.rectify. This was a major headache.
> Has anyone else run into this? Is there any way to "rectify" this
> problem? ;-)
> ____________________
> C. Michael Barton, Professor
> Department of Anthropology
> PO Box 872402
> Arizona State University
> Tempe, AZ 85287-2402
> USA
> Phone: 480-965-6262
> Fax: 480-965-7671
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
