[GRASS5] Re: [GRASSLIST:1768] Re: realtime_gps
Radim Blazek blazek at itc.it
Mon Nov 17 05:36:09 EST 2003
On Saturday 15 November 2003 15:46, Paul Kelly wrote:
> Hello
> On Sat, 15 Nov 2003, Maliheh wrote:
> > Thank you so much Hamish for your help.
> > but in grass5.7 when I use g.projinfo it shows:
> > can't read "opttype(1)":no such element in array
> > Now what should I do?
> Don't use g.projinfo in 5.7; use the newer g.proj. Specifically,
> "g.proj -jf" will give you the projection parameters for your current
> location in PROJ.4 format. Type "g.proj help" to see the other options
> (there is no man page yet).
> Paul
Should I remove grass51/scripts/g.projinfo/ ?
Radim
