[GRASS5] Re: [GRASSLIST:1768] Re: realtime_gps
Paul Kelly paul-grass at stjohnspoint.co.uk
Mon Nov 17 04:49:59 EST 2003
Hello Radim
On Mon, 17 Nov 2003, Radim Blazek wrote:
> Should I remove grass51/scripts/g.projinfo/ ?
I can confirm that I intended g.proj as a replacement for g.projinfo (and
ultimately also g.setproj...in a few years!), so if you are happy with the
behaviour of g.proj so far, go ahead and remove g.projinfo
Paul
