[GRASS5] GRASS5.7: compile error: " No rule to make
target`OBJ.i686-pc-linux-gnu/get_proj.o"
Moritz Lennert
mlennert at club.worldonline.be
Mon Nov 17 11:23:29 EST 2003
Radim Blazek said:
> On Monday 17 November 2003 16:50, Moritz Lennert wrote:
>> I just redid a cvs update in the 5.7 tree, followed by make distclean,
>> ./configure (+options), make mixclean, and make mix. I get exactly the
>> same compilation error. Here is what I have in the ./lib/proj directory:
>> alaska.lla datum.c Makefile ntv1_can.dat stlrnc.lla
>> WO.lla
>> conus.lla ellipse.c MD.lla nzgd2kgrid0005.gsb stpaul.lla
>> convert.c FL.lla nad2bin prvi.lla TN.lla
>> CVS hawaii.lla nad2bin.c stgeorge.lla WI.lla
>> No get_proj.c nor do_proj.c...
> I think, that you shoud start by make distclean, make mixclean
> followed by cvs update, otherwise symlinks are in way.
That seems to have been it, except that I had to do the make mixclean
before the make distclean, because the latter erases the Makefile defining
the former.
Thanks Radim and Paul !
Moritz
