[GRASS5] GRASS5.7: compile error: " No rule to make target`OBJ.i686-pc-linux-gnu/get_proj.o"
Radim Blazek blazek at itc.it
Mon Nov 17 12:14:47 EST 2003
On Monday 17 November 2003 16:50, Moritz Lennert wrote:
> I just redid a cvs update in the 5.7 tree, followed by make distclean,
> ./configure (+options), make mixclean, and make mix. I get exactly the
> same compilation error. Here is what I have in the ./lib/proj directory:
> alaska.lla  datum.c     Makefile   ntv1_can.dat        stlrnc.lla  WO.lla
> conus.lla   ellipse.c   MD.lla     nzgd2kgrid0005.gsb  stpaul.lla
> convert.c   FL.lla      nad2bin    prvi.lla            TN.lla
> CVS         hawaii.lla  nad2bin.c  stgeorge.lla        WI.lla
> No get_proj.c nor do_proj.c...
I think, that you shoud start by make distclean, make mixclean
followed by cvs update, otherwise symlinks are in way.
Radim
